2002 Toyota Camry OIL Smoke
RAYROD69
  • 2002 TOYOTA CAMRY
  • 4 CYL
  • 4WD
  • 85,000 MILES
My car lets out smoke in the morning after an overnight parking. During the day it does not smoke only when it si parked for extended number of hours. Mileage is good, oil change has been done every 3/4K miles and even the timing belt has been changed, which for the mileage is recommended. No leakage and no additional oil need to be added between oil changes. Miighe I have to do a flushing of the engine? I should not have to with only 85K miles, right?
Rayrod.
Thursday, December 18th, 2008 AT 4:37 PM
ZACKMAN
  • 4,202 POSTS
Yes you should. For best result, you should let the professionals do it, but you can do it yourself at home providing that you follow the instructions. Kits such as 08963 by 3M has easy to follow direction...
https://www.2carpros.com/forum/automotive_pictures/55316_itemphpid60455031587_1.jpg
Thursday, December 18th, 2008 AT 7:37 PM
