2002 Toyota Camry no shifting 2nd to 3rd when cold
59,000 MILES • 4 CYL • FWD • AUTOMATIC
TOYO
I have a camry 2002, when temperature is below 0, the transmission shifts from 1st to 2nd gear; however, it will not shift to the 3rd and 4th gear until I drive the car for at least 1 or 2 miles, then is normal and shifts ok
what can can possibly cause the problem besides the low temperature?
Mar 31, 2009 at 8:12 AM
  • 75,988 POSTS
If the fluid level and the condition of it are okay-get these sensors checked out -coolant temperature/throttle and vehicle speed sensors, the computer uses these sensor's input signals to command and control the transmission.
Mar 31, 2009 at 8:21 AM
