2002 Toyota Camry No power to gauges, speedometer, fuel, ta
140,000 MILES • 6 CYL • FWD • AUTOMATIC
SPACEPUPP
I have no sight gauges in my Toyota Camry. None of the gauges are working, it looks like there is no power to them. How do I fix this? I have checked fuses they are all good.
Aug 1, 2009 at 3:58 AM
STEVEW84
  • 673 POSTS
Does anything work on the cluster? No Speedo, Tach, coolant,etc? Any codes at all? Any dummy lights on? ABS, CEL, etc?
Aug 3, 2009 at 11:47 AM
SPACEPUPP
The dumby lights work and so does the transmission lights, but no back lighting.
Aug 3, 2009 at 4:57 PM
STEVEW84
  • 673 POSTS
You need to check to see if you are getting a power and ground to the instrument cluster. From what it sounds like you just may have a bad cluster. You need to get a service manual and see what wires they are. If you had a diagnostic scanner you should be able to read data just to make sure that everything is registering. Do you have any codes?
Aug 4, 2009 at 12:03 AM
