2002 Toyota Camry INTERIOR DOME LIGHT
AM62
Electrical problem
2002 Toyota Camry 4 cyl Two Wheel Drive Automatic
MY CAR INTERIOR DOME LIGHT AND IGNITION SWITCH LIGHT DID NOT COME ON AFTER I REPLACE DOME LIGHT BURN FUSE BUT DOME LIGHT WORK FINE WHEN YOU SET IT TO ON POSITION WHAT I MEANS IT STILL NOT WORKING WHEN YOU SET IT DOOR POSITION
May 11, 2010 at 4:15 AM
  • 31,937 POSTS
Hi there,
The dome light switch on these cars are very flimsy and often fail, have a close look at the contact of the small switch, they can burn out or warp and not make a good contact.
mark (mhpautos)
May 11, 2010 at 9:27 PM
