The idle being low could be due to a couple things but more then likely we need to force the ECM to relearn the idle.
Here are a couple guides that will help with this issue just to get us started:
https://www.2carpros.com/articles/stall-at-idle
We should check the throttle bore and make sure it is not dirty. If it is then we need to clean it. Here is a guide that will help with doing this:
If none of this works let's try this process to try and trick the ECM into relearning the idle.
• Remove EFI and ECTS fuse in under hood fuse box for 3 minutes
• Reinstall both fuses
• Hold the throttle plate close completely with your finger
• Have someone turn ignition switch ON
• Release throttle as soon ignition is ON
• Reinstall throttle body boot, start engine and let run at idle for 5 minutes before road test
Idle speed should be between 550 and 650 RPM's
Let us know what you find. Thanks
Jul 14, 2021 at 11:41 AM
