This could be a couple things but we need to start with making sure the battery that you have is not faulty. Here is a guide that will help with this:
However, if the battery checks out then we need to start with this guide and see what turns up as it will help with this issue:
https://www.2carpros.com/articles/stall-at-idle
Lastly we need to check the idle air control valve as they can get stuck closed and it basically cuts the air off when the engine is idling. Here is a guide that will help clean this which should solve it if that is the issue:
https://www.2carpros.com/articles/idle-air-control-valve-service
Let us know what you find and we can go from there. Thanks
SPONSORED LINKS
Friday, February 5th, 2021 AT 6:19 PM
