2002 Toyota Camry Fuel injector
117,000 MILES • 4 CYL • 2WD • AUTOMATIC
RYSTRAT
I changed out the spark plugs and #1 cyl fuel injector after check engine code said cylinder 1 misfire. After doing so the check engine light came off, but the car now runs at really low rpms and sometimes dies. I can hear a "sucking" sound when pushing the gas pedal. What might be the problem or what did I do wrong?
Oct 25, 2008 at 11:34 AM
CAMERONBRIA
  • 8 POSTS
Check theair intake hoses. It sounds like one has been bumped off or may have been damaged causing a vacuum leak.
Oct 26, 2008 at 11:13 AM
