2002 Toyota Camry Front Wheel Bearings
2002 TOYOTA CAMRY
19,600 MILES • 4 CYL • FWD • AUTOMATIC
SUGARDAWG
How to replace/repair the front wheel bearings on 2002 LE Toyota Camry properly?
Sep 9, 2008 at 2:04 PM
  • 31,937 POSTS
Hi there,
you need to remove the entire hub assembly and using a hydraulic press and the correct special tools press out the bearing assembly. this is often beyond the capabilities of home mechanics, so get a quote from your mechanic first.
mark (mhpautos)
Sep 9, 2008 at 3:09 PM
