2002 Toyota Camry EXHAUST
225,000 MILES • 4 CYL • 4WD • AUTOMATIC
JCREAVES
My 2002 Toyota Camry has smoke coming from the exhaust upon initial start after a 12-24 hour period. It's a grey smoke. Otherwise the car runs fine. I resently had the PURGE VALVE replaced. The exhaust was smoking prior to the replacement.
Jul 12, 2008 at 8:18 AM
KHLOW2008
  • 41,812 POSTS
Hi JCREAVES,
The engine should be consuming some engine oil and I would say the smoke is due to the valve seals.
You need to replace them to reduce the smoke.
Jul 12, 2008 at 10:12 AM
