2002 Toyota Camry Engine Failure
131,434 MILES • 4 CYL • 2WD • AUTOMATIC
RHAROLD
  • 8 POSTS
Recently had timing chain repaired on my 2002 Toyota Camry and 5 days later had engine failure need to replace the engine . Is there a correction between the two ?
Jul 24, 2009 at 7:38 AM
STEVEW84
  • 673 POSTS
you have no timing chain. you have timing belt. that motor is not an interference motor. Even if the timing belt broke the valves would not hit the pistons. How do you know the engine failed?
Jul 24, 2009 at 3:08 PM
STEVEW84
  • 673 POSTS
I apologize, I thought I read 2001 not 2002.
Why did you have the chain replaced in the first place?
Jul 24, 2009 at 3:09 PM
RHAROLD
  • 8 POSTS
Engine keep coming on after purchase the car took Pep Boys for diagnostic test determine malfunction in the timing belt .Took it t another mechanic determine that timing belt needs to be replaced . Right now have another mechanic looking at root cause of engine failure .
Jul 25, 2009 at 2:06 AM
STEVEW84
  • 673 POSTS
Do yo\u remember what the code was? That would be a huge help to see if the chain had to be replaced in the first place.
Jul 25, 2009 at 2:31 AM
RHAROLD
  • 8 POSTS
Code was 1165
Jul 25, 2009 at 2:37 AM
STEVEW84
  • 673 POSTS
There is no p1165 in OBD2 diagnostics.
Jul 25, 2009 at 4:14 AM
RHAROLD
  • 8 POSTS
Do not remember the code also what would be the indicators that my car would to have the timing belt kit replaced ?
Jul 25, 2009 at 5:16 AM
