2002 Toyota Camry engine
ROSEBUD25
  • 2002 TOYOTA CAMRY
  • 6 CYL
  • 4WD
  • 11,200 MILES
As I am driving periodically my car acts like its not getting enough gas. It starts to stall as I am applying the break. I have to turn car completely off. Place it in park. Then rev engine to get it to go. I then have to park the car for about a 1/2 hour then it drives completely normal. Ive had the car just stall while waiting for light to turn or slowing to a stop.
Thursday, August 14th, 2008 AT 5:48 PM
KHLOW2008
  • 41,814 POSTS
Hi rosebud25,
When in Neutral you are not able to keep the engine running by revving?
Looks like the idling circuit is not working properly and a cleanup of the throttle body and IAC should get the idling speed up.
If that does not help, the MAP sensor is the next on the checklist.
Sunday, August 17th, 2008 AT 7:01 AM
