2002 Toyota Camry Changing the oil pan gasket in 2002 Toyot
2002 TOYOTA CAMRY
81,000 MILES • 4 CYL • FWD • AUTOMATIC
BWHITEHAIR
My wifes car has been leaking oil from the oil pan gasket for a while now. My mechanic said it was listed as 4 hours labor to replace. That led me to think it was a difficult job. I contemplated changing it myself but dont know if ill get myself into more than i can handle. Any advice or facts on this problem?
May 16, 2010 at 10:37 AM
  • 31,937 POSTS
Hi there,
You will have to remove the exhaust engine pipe the long engine mount support splash trays to access the sump, this is a bit time consuming and it will be worse working on the ground, but it is not hard,
mark (mhpautos)
May 16, 2010 at 1:32 PM
