2002 Toyota Camry BRAND NEW BRAKES
2002 TOYOTA CAMRY
BANDITCMW2
Brakes problem
2002 Toyota Camry 4 cyl Automatic 150400 miles
I HAD BRAND NEW ROTORS AND PADS INSTALLED TODAY. UPON DRIVE AWAY MADE SCREECHING NOISE WHICH WAS VERY LOUD AND WASN'T EVEN APPLYING BRAKE. THEY REMOVED PADS AND INSTALLED SEMI-METALLIC INSTEAD...SAME PROBLEM..SCREECH IS INCREDIBLY LOUD AND OCCURS AS YOU DRIVE WITHOUT EVEN APPLYING THE BRAKES. WHAT IS CAUSING THIS? IS IT BECAUSE THEY PUT THE CALIPER TOO LOW OR WHAT?
Sep 13, 2009 at 5:12 PM
  • 31,937 POSTS
Hi there,
Check that the tin backing plate is not touching the rotor.
mark (mhpautos)
Sep 13, 2009 at 7:57 PM
