2002 Toyota Camry Axle Boots
2002 TOYOTA CAMRY
11,500 MILES • 4 CYL • FWD • AUTOMATIC
GOJIGGY
As I was getting a oil change, my local dealer said one of my axle boots was leaking and offered to change both axle boots for $285. I asked a mechanic somebody referred to me and they offered to replace axle boots and axles on both sides of the car for $260. Do I generally need to replace axle boots on both sides of the car if only one is leaking? Do I need to change the axle? The mechanic said it should be replaced along with the axle boots even before he looked at the car? Thanks.
Apr 9, 2008 at 2:30 AM
  • 31,937 POSTS
Hi there, only change the drive shaft if it is worn, when the boot splits the grease is lost and the CV will start to run dry and damage the bearings in side. this is often heard as a click when turning. if the boot has only just let go, you should get away with re greasing it and fitting a new boot.
Mark (mhpautos)
Apr 9, 2008 at 11:40 PM
MMPRINCE4000
  • 8,548 POSTS
What Mark said is very true, however:
I have a 1991 Corolla. The boot kit (inner and outer) from NAPA costs $40. A new (not remanufactured) axle with new boots (already installed) and all new bearings costs $76 from NAPA, while a reman'd axle with new boots costs $56.
You have to disassemble the old axle to put the new boots on, while with the new or reman'd axle you remove the old one and replace it.
There is more labor involved in re-booting the old axle than putting in a new one.
So it comes down to a matter of money rather than what you need.
I would also have them install new axle seals while they are at it.
Apr 10, 2008 at 12:12 AM
