2002 Toyota Camry After battery replaced, engine idle speed
2002 TOYOTA CAMRY
KENTEBURG
Electrical problem
2002 Toyota Camry 4 cyl Front Wheel Drive 76000 miles
Battery was very weak. Replaced battery. Now idle speed is very low, and engine dies while idling. No check engine light on. Battery voltage at idle is 13.8 volts.
Jun 21, 2010 at 1:17 PM
Hi kenteburg, Welcome to 2carpros an TY for the donation
You threw off the idle air control valve target speed by the computer by disconnecting the battery-it needs to go thru an idle relearning process could be as much as 40 key cylces to regain it-
Jun 21, 2010 at 2:09 PM
