Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Engine
Symptoms
Not Running
2002 Toyota Camry
2002 TOYOTA CAMRY
62,000 MILES • 4 CYL • FWD • AUTOMATIC
DON2010
MEMBER
1 POST
car wont start!! only here relay clicking from from fuse box under hood.replaced it but still have same problem
Oct 1, 2010 at 6:03 PM
Experienced Mechanic
If its not coming from the anti theft deterrent and will not crank over when key is at starting position do below
Could be the starter, starter relay, transmission position switch and ignition switch assuming the battery and connections are good.
Oct 2, 2010 at 12:16 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
