2001 Toyota Camry VAV SENSOR FOR EGR
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
PILLSBURY
  • 9 POSTS
hi guys! a while ago i had a VAV SENSOR for the EGR replaced on my camry. i'm interested in where this is. i'd lke to get a look at it. my haynes manual shows it being in the center of the engine near the egr/ignition wires,air intake area. can you provide a picture of one, or a pdf showing where it is? thanks. my mechanic wrote down the part number on my invoice as # 25860-74050
Jan 24, 2008 at 1:32 PM
BMRFIXIT
  • 19,053 POSTS
[quote:b07d906095="pillsbury"]Other Category problem
2001 Toyota Camry 4 cyl Two Wheel Drive Automatic 80000 miles
hi guys! a while ago i had a VAV SENSOR for the EGR replaced on my camry. i'm interested in where this is. i'd lke to get a look at it. my haynes manual shows it being in the center of the engine near the egr/ignition wires,air intake area. can you provide a picture of one, or a pdf showing where it is? thanks. my mechanic wrote down the part number on my invoice as # 25860-74050[/quote:b07d906095]
I don’t have a pic but I can tell you its locations
Solenoid under the intake manifold and almost behind the ps pump
if you trace or follow the vacuum line from EGR to goes down to it
also vsv located at top left of the engine almost at the manifold
Jan 24, 2008 at 2:07 PM
