2001 Toyota Camry trip a
2001 TOYOTA CAMRY
RHERNANDEZ
2001 Toyota Camry 6 cyl Two Wheel Drive Automatic
I went to vacumm my car and when I restarted my car on the milage odometer instead of showing the total milage it show on the top "TRIP A" and another milage total. How can I change it back?
Mar 12, 2010 at 9:37 AM
SERVICE WRITER
  • 9,123 POSTS
There is a black rod near the odometer on the cluster. Typically to the right. When you press it it will change the mileage to trip A or Trip B or back to mileage.
FYI:
By holding it in on the trip A or B, it will reset the counter to 0.
This is also used to reset the oil change intervals. By bringing it to the mileage display with the key on is the first step. turn the key off and hold the bleack rod in again and turn the key on. Little dashes will appears and one by one disappear. The oil change counter is then reset.
Mar 12, 2010 at 9:49 PM
