2001 Toyota Camry starter
2001 TOYOTA CAMRY
ZEROPOINT1
Electrical problem
2001 Toyota Camry 4 cyl Two Wheel Drive Automatic
How do I replace the starter on a 2001 Toyota Camry?
Aug 11, 2009 at 11:34 AM
BMRFIXIT
  • 19,053 POSTS
Disconnect negative battery cable and then positive cable. Remove battery and tray. If equipped with cruise control, remove cruise control actuator cover, cruise control actuator and actuator bracket from body mount.
remove starter terminal/wire cover and remove starter wires. Remove starter. To install, reverse removal procedure
Apr 25, 2020 at 6:04 AM
