2001 Toyota Camry Rattling
132,000 MILES • 6 CYL • 2WD • AUTOMATIC
SORIAS1970
In 2006 took to have a full tune-up change fuel pump, water pump, flush radiator, timing belt, sparks plug, motor oil change and transmission.
Now my car starting to rattling and when it in idle the temperature starts going up. it rattles also when the AC is on
Jul 1, 2008 at 1:37 PM
KHLOW2008
  • 41,812 POSTS
Hi sorias1970,
Check if there is enough coolant in the radiator and if the radiator fans are working.
Find out where the noise is coming from.
Jul 2, 2008 at 6:02 AM
