First of all, the radiator fan should turn on when the engine reaches its operating temperature. It also turns on when the A/C is on.
An inoperative radiator fan can be due to a bad relay, faulty wiring, defective coolant temperature sensor or a bad fan motor.
https://www.2carpros.com/articles/how-an-electric-cooling-fan-works
First check the relay. This vehicle has 3 relays for the cooling fan. They are located in the under-hood fuse box.
I have attached diagrams on how to test the relays as well as the temperature sensor and the fan replacement procedure below for your reference.
Images (Click to enlarge)
Jan 29, 2022 at 12:30 PM
