High beam does not work?
166,000 MILES • 4 CYL • FWD • AUTOMATIC
BRODEUB
High beam does not work on my 01 camry. Where is the headlight relay and wire harness located? Fuses are ok and dimmer switch has continuity
Dec 26, 2008 at 8:49 PM
  • 31,937 POSTS
Hi there,
The headlight switch is probably the problem, if it was a ground or the power supply the other low beam lights would not work, here is how to change the headlight switch out to fix the problem. Also I have included the headlight wiring diagrams so you can see how the system works.
Dec 26, 2008 at 9:10 PM
