2001 Toyota Camry Gasoline fume smell
2001 TOYOTA CAMRY
180,000 MILES • 4 CYL • FWD • AUTOMATIC
TIM2166
Hello. I can occasionally smell gas fumes inside my 2001 Camry. The smell seems to be coming through the AC vent, mostly when the car is first started or when stopping after driving at highway speeds. I have checked under the car and in the engine compartment for leaks, including at the fuel filter and the fuel rail, but have not seen any leaks. Any idea where this gas smell may be coming from? Thanks.
Oct 26, 2009 at 12:38 AM
MMPRINCE4000
  • 8,548 POSTS
You either have a small gas leak in fuel system or a leak in EVAP system.
A fuel pressure test will rule out fuel leaks.
Oct 27, 2009 at 3:00 AM
