I have a 2001 Toyota Solara. For about a month now I have been feeling a "thunking" vibration under the floor by the pedals and it's getting worse.Most noticeable at speeds above 40 mph. I thought it might be bad rotors so I changed them and all the brakes out. It made no difference. I looked under the car several times and I can't find anything wrong. The CV joint boots aren't torn. Someone told me to check the motor mounts. Visibly, I don't see anything wrong, but when I put the vehicle in gear and run up the engine with the brakes applied, the motor moves about 2 inches to the rear. My question is does this sound like a bad mount?
Aug 29, 2008 at 2:18 PM
