2001 Toyota Camry Emergency brake light on
76,500 MILES • 4 CYL • FWD • AUTOMATIC
SHASTASTEVE
Recently I accidently left my ignition key in the on position overnight. The next morning I discovered that my emergency brake light comes on intermittently while driving the car. If I brake hard or turn a corner the emergency brake light comes on again. After a few seconds the light goes off. This will happen several times a trip, no matter how long or short the trip is.
Is there a switch or somthing that burned out and needs replacing?
Aug 7, 2008 at 9:27 AM
KHLOW2008
  • 41,812 POSTS
Hi shastasteve,
You need to check the fluid level in the brake master cylinder reservoir.
Aug 15, 2008 at 5:03 AM
