2001 Toyota Camry EGR regulator and vacuum switch
122,000 MILES • 4 CYL • FWD • AUTOMATIC
TOYO2001
Check engine light came on for a day and turn off by itself, I let mechanic check it out he said code came up for EGR fault. He recomments to change EGR regulator and vacuum switch sensor. The car run fine except when you slow down between 30 to 40 miles and apply gas pedal again it seem like car doesn't want to move or real slow untill it reach certain speed or RPM. Does ERG cause this problem. Thanks.
Oct 17, 2008 at 2:05 PM
BLACKOP555
  • 10,386 POSTS
its possible, or there could be a few things contributing to it such as possible vaccum leak.
what i would be doing is posting the code that came up back to me, not what it means. ie P0300.
or whatever else your code appears to be that way i can tell you what is wrong.
Oct 18, 2008 at 1:28 AM
TOYO2001
Mechanic said it is P0401 fault, he said most common on camry is EGR vacuum modulator or Vacuum Switch Valve, he said replace booth of them is best way. He did check EGR Valve it is good. Thanks
Oct 18, 2008 at 3:20 AM
BLACKOP555
  • 10,386 POSTS
sounds like your mechanic knows what hes talking about.
replace and see how it goes, should clear right up.
Oct 19, 2008 at 6:33 AM
