2001 Toyota Camry check engine light
2001 TOYOTA CAMRY
109,855 MILES • 4 CYL • FWD • AUTOMATIC
KHALEEL REHMAN
My car had the CHECK ENGINE light on. The OBD II diagnosis showed code P 0401 which was interpreted as EGR Valve malfunction. On my mechanic's advice the spark plugs, wires, fuel filter, air filter and EGR valve ( this was purchased from the Dealer) were changed. The light went off for a week and returned. Now the mechanic says I have to go to the Dealer to pin point the defect and repair. Your advice please.
Mar 10, 2008 at 3:34 PM
  • 31,937 POSTS
Hi there,
First check the code, if it is the same as the last set code, there is still a problem in the system. The dealer will have a more detailed flow chart check to help pinpont this fault, your mechanic should at least do a code read an inspection just in case he has missed something.
mark (mhpautos)
Mar 10, 2008 at 4:08 PM
