2001 Toyota Camry Car exhaust lets out a cloud of smoke whe
70,000 MILES • 4 CYL • FWD • AUTOMATIC
OHME
About 1 mth ago, I took my car to the shop to repair a serious oil leak. A new gasket, water pump, timing belt later, I get my car back. A few days later I note that after getting off the highway and onto regular traffic speeds, the car would hesitate a bit (like a slight tug) upon acceleration from the first full stop, then a huge cloud of smoke would come out of the exhaust. This would never happen while strictly in regular street traffic.
I took it back and supposedly, they check the car and said that all it needed was some transmission fluid, because somehow I had none. I get my car back but the problem with the hesitant engine and smoke billowing after highway driving persists. I call the mechanic and he is telling me that I probably need a tune up.
I am very upset to have to take the car back what I consider an incompetent and perhaps crooked mechanic. What is the problem here?.
Apr 30, 2009 at 2:11 PM
  • 75,988 POSTS
What's the color of the smoke you're seeing???
Apr 30, 2009 at 2:15 PM
OHME
The color of the smoke seems white or grey even. Thanks for your help.
Apr 30, 2009 at 2:33 PM
  • 75,988 POSTS
I want you to distinguish it closely if its mostly white/bluish/black
Apr 30, 2009 at 2:39 PM
OHME
The color of the smoke is mostly white.
May 2, 2009 at 9:51 AM
  • 75,988 POSTS
You're burning coolant in the cylinders could be due to a blown headgasket cracked head or block and intake manifold leak.
I recommend a block and pressure tests to find out exactly where its leaking from.
May 2, 2009 at 9:57 AM
OHME
Thank you very much...now at least I have some idea of what to request to be checked.
May 2, 2009 at 1:44 PM
