2001 Toyota Camry blower motor
2001 TOYOTA CAMRY
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
SOBREM
blower motor { htr & a.c.} has 4 speeds & only the highest speed works. is there a blower module that i can replace myself? where is it located?
Mar 17, 2009 at 4:26 AM
GRSMNKY
  • 33 POSTS
sounds like the resistor went bad and only the direct contact works which is fastest speed. The resister is located next to the blower fan/cage. It has a large electrical plug with many wires and is usually attached by two screws to the blower asssembly
Mar 16, 2021 at 11:39 AM
