Should I use the expensive fluid from the dealer or just use Dexdron III as written on the dipstick?
Feb 7, 2008 at 3:41 PM
DANNY L
✓Experienced Mechanic
Hello, I'm Danny.
If you want to save some money Dexron III works just as good as the dealer brand. I've attached a picture below of the automatic transmission requirements and specifications. Hope this helps and thanks for using 2CarPros.
