HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Engine
Tune-up
Estimate
2000 Toyota Camry tune up
EMAR1
MEMBER
2000 TOYOTA CAMRY
4 CYL
FWD
AUTOMATIC
74,000 MILES
What does a major tune up entail and how much does it cost? Thx.
Thursday, June 5th, 2008 AT 8:17 AM
KHLOW2008
MECHANIC
Hi emar1,
A major tuneup entails the following checks and cleaning or replacement where necessary.
1. Spark plugs, cables, distributor rotor, cap and ignition timing.
2. Idling speed, throttle body.
3. Fuel pressure and line.
4. Valve clearances.
As for the cost, sorry I am unable to provide, you need to check locally.
Thursday, June 5th, 2008 AT 1:21 PM
Please
login
or
register
to post a reply.
Related Tune-up Estimate Content
2003 Toyota Camry 90,000 Tune-up
I Would Like To Maintain The Running Of My Car. I Am Looking To Put It In For A 90,000 Mile Tune-up. What Will Be Involved In This Tune-up...
Asked by
kevphenix
1 ANSWER
2003
TOYOTA CAMRY
VIDEO
Is it Safe to Drive Check Engine Light?
Instructional repair video
GUIDE
Check Engine Light
Why is my check engine or service engine soon turned on? In this guide we talk about what this is associated with this notorious light, what it is used for and what you...
2000 Toyota Camry Crank Shaft Pulley
The Bolt Holding The Crank Shaft Pulley On Is It A Left Hand Or A Right Hand Thread?
Asked by
robertgarcia72357
2000
TOYOTA CAMRY
2000 Toyota Camry Changing The Motor Oil
My Camry Has Been Burning Oil More Than Normal Lately And I Would Like To Know If You Suggest That I Change The Motor Oil To A Heavier...
Asked by
dlm29
1 ANSWER
2000
TOYOTA CAMRY
2000 Toyota Camry Engine Replacement
I Am Looking For A Manual Of Some Kind That Has Engine Removal/installation Instructions. I Have Dome Engine Work Before, But Never On A...
Asked by
rprouse
1 ANSWER
2000
TOYOTA CAMRY
2000 Toyota Camry Throttle Body
2000 Toyota Camry 4 Cyl Two Wheel Drive Automatic My Throttlebody Sticks When I Try To Give The Car Gas And Its Not My Cabels Or My...
Asked by
sean24
1 ANSWER
2000
TOYOTA CAMRY
VIEW MORE
Code Read Retrieval/Clear Scion
How to Read Codes
Code Read Retrieval/Clear Mercedes Benz
