HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Engine
Throttle Body
2000 Toyota Camry throttle body
SEAN24
MEMBER
2000 TOYOTA CAMRY
2000 Toyota Camry 4 cyl Two Wheel Drive Automatic
my throttlebody sticks when I try to give the car gas and its not my cabels or my pedal?
Tuesday, March 3rd, 2009 AT 8:22 PM
BLACKOP555
MECHANIC
Try cleaning out the throttle body inside by the butterfly valves pivot points.
And then lube it up with wd40 and work it.
How much tension is on the return spring? Does it feel weak?
Tuesday, March 3rd, 2009 AT 9:25 PM
Please
login
or
register
to post a reply.
Related Throttle Body Content
Accelerating Hard
Why The Accelerate Is Hard ( Like The Plate Inside The Throttle Is Touching The Body ) But Give More Force To It Then It Works Normal. How...
Asked by
hiep nguyen
1 ANSWER
1994
TOYOTA CAMRY
GUIDE
Throttle Body Service
The throttle body or throttle actuator as they are called on newer cars is used to meter the engine air intake thus controlling the engine RPM and power output via the gas...
2000 Toyota Camry Crank Shaft Pulley
The Bolt Holding The Crank Shaft Pulley On Is It A Left Hand Or A Right Hand Thread?
Asked by
robertgarcia72357
2000
TOYOTA CAMRY
2000 Toyota Camry Changing The Motor Oil
My Camry Has Been Burning Oil More Than Normal Lately And I Would Like To Know If You Suggest That I Change The Motor Oil To A Heavier...
Asked by
dlm29
1 ANSWER
2000
TOYOTA CAMRY
2000 Toyota Camry Engine Replacement
I Am Looking For A Manual Of Some Kind That Has Engine Removal/installation Instructions. I Have Dome Engine Work Before, But Never On A...
Asked by
rprouse
1 ANSWER
2000
TOYOTA CAMRY
Possible Tune-up Questions For 2000 Camry
I Have A 4-cylinder Automatic 2000 Camry That's Misfiring In The 3rd And 4th Cylinders. I Am Not Very Knowledgeable About Cars, But The...
Asked by
suttles95
1 ANSWER
2000
TOYOTA CAMRY
VIEW MORE
Service Throttle Body Ford F-150 4.6L V8
Service a Throttle Body Housing Ford
