2000 Toyota Camry tires
88,000 MILES • 4 CYL • 2WD • AUTOMATIC
BRICK9
orginial tires are 205 65R 15 will a 205 70R 15 fit the car? clearing the struts? wanting to replace all four tires with the 205 70 R 15....if possible Help!!!
Thanks
Apr 1, 2010 at 4:44 AM
FREEMBA
  • 1,152 POSTS
It's basically saying that the 205 70R 15 is narrower than the 205 65R 15. So they should fit with no problem.
Also, check your tires size again, a 16 inch rim might be stock for this car. Either way, whether its' a 15 or 16 inch rim the size you want to change to should work.
Apr 7, 2010 at 2:20 PM
