2000 Toyota Camry Tachometer Stoped Working
72,000 MILES • 4 CYL • FWD • AUTOMATIC
AHAPNK
This morning my Tachometer stoped working and reads 0 RPM. All other gauges seem to be working fine. No other problems seem apparrent. What could be the problem and how can I fix it?
Aug 2, 2009 at 12:24 PM
STEVEW84
  • 673 POSTS
is your check engine light on or are there any codes?
Aug 3, 2009 at 11:25 AM
AHAPNK
There is no check engine light nor any other anomalies that I can find other than the Tachometer just seemed to quit working suddenly.
Aug 3, 2009 at 3:45 PM
STEVEW84
  • 673 POSTS
Well seeing as how engine speed is measured by the crankshaft sensor and you said that there is no CEL and no driveability problems I would probably say that you have a bad cluster. However, you need to make sure that you are getting a signal to the instrument cluster itself. I would make sure you are getting a ground at pin #5(brown) and get a scope and make sure you are getting a signal from pin#8(brown-orange). If you had a diagnostic scanner you should be able to do it with that. Also, do you have any trouble codes?
Aug 4, 2009 at 12:09 AM
