Located/bolted between the engine and the transmission (showing mostly above the transmission)
Removal:
1. Remove battery and tray.
2. If with cruise control, remove cruise control actuator.
a. Disconnect the actuator connector and clamp
b. Remove the 3 bolts and disconnect the actuator with the bracket.
3. Remove the starter
a. Disconnect the starter connector.
b.Remove the 2 bolts and the starter.
c. Remove the nut and disconnect the starter cable.
Oct 1, 2008 at 7:15 AM
