2000 Toyota Camry Slipping?
FSTCOOK
  • 2000 TOYOTA CAMRY
Transmission problem
2000 Toyota Camry V8 Automatic 108, 00 miles
When I apply brakes, just before the car stops completely, it shudders and then stops. A brake technician told me that my transmission was slipping in thelower gears. I put in a half bottle of transmission slip repair liquid and it stopped for about 2 months. Now it is doing it again. Should I keep adding the fluid or does it need to be checked right away? My trans. Fluid levels were high when I added the fixit solution. Could it just have two much fluid? Does it need to be drained?
Please advise what I should do!
Friday, July 23rd, 2010 AT 9:39 AM
LEGITIMATE007
  • 5,121 POSTS
Yes it could be too high and of course that is what we want to check first. I would do a tranny service, which is :change the fluid and filter. See how it goes from there. Let me know
Friday, July 23rd, 2010 AT 9:42 AM
  • 31,937 POSTS
Go get a test and report done, the longer you leave this the more it is likely to cost to repair, cans of fix it just don't work as a permanent solution.
Mark (mhpautos)
Friday, July 23rd, 2010 AT 9:43 AM
