2000 Toyota Camry Side View Mirrors
90,000 MILES • 4 CYL • 2WD • AUTOMATIC
BLCOMBS
I need to replace the side view mirrors on my 2000 Camry. They are electric, non-heated. The car was manufactured in Japan. I need instructions on how to replace the mirrors. Thanks.
Jan 5, 2008 at 4:46 AM
LEGITIMATE007
  • 5,121 POSTS
inside your door behind the side mirror is a piece of black plastic (triangle shaped) pull that off and there will be 3 screws to take out, and the mirror is off. unplug the wire connector and toss that aside. Clean off the old gasket or foam weather stripping.
Put new one on and pay attention to the foam weatherstripping and were to stick it so that it all matches.
Then plug the connector in, and reassemble everything.
(connector for heated only)
Jun 11, 2020 at 7:34 AM
