2000 Toyota Camry Rotor replacement
2000 TOYOTA CAMRY
176,000 MILES • 6 CYL • 2WD • AUTOMATIC
MOON2089
I removed caliper and tried to remove the rotor but it did not come out. I also tried hitting with hammer but did not help. It looks like it has 2 screws that are holding the rotor. Let me know what else and how to remove other things to remove front rotors.
Thanks.
Jan 9, 2008 at 2:50 AM
MASTERTECHTIM
  • 4,750 POSTS
YOU HAVE TO REMOVE THE FLUSH MOUNTED PHILLIPS HEAD SCREWS THEN HIT WITH A BIG HAMMER. **YOU MIGHT NEED A IMPACT SCREWDRIVER. ALSO IF THERE ARE NOT PHILLIP SCREWS HOLDING IT ON, JUST SCREW HOLES IN THE ROTORS, YOU CAN RUN BOLTS INTO THEM, THIS WILL PRESS OFF THE ROTOR WHILE YOU HIT IT.
Jan 9, 2008 at 3:52 AM
