2000 Toyota Camry Power Window
150,000 MILES • 4 CYL • FWD • AUTOMATIC
JANMUL
Most of the time my power windows work fine. Probably one time in ten the driver side window will just do nothing. There is no sound of any effort to do anything. All other windows work fine. Its like that button does nothing then it will just start to work again.
Sep 23, 2010 at 3:32 AM
KHLOW2008
  • 41,812 POSTS
Hi Janmul,
You could have an intermittently failing switch or the motor is failing.
When problem occurs, bang the door panel a few times and retest.
If window starts working then, the motor is on its way out.
Sep 24, 2010 at 2:34 AM
