Hi motor264,
Thankyou for the donation.
Insufficient EGR flow are usually due to clogged EGR valve and its passage from the exhaust port to the EGR valve seat. Remove the EGR valve and clear the accumulated carbon deposits in the passage and it should solve the problem unless the EGR valve is faulty which requires replacement.
SPONSORED LINKS
Friday, September 26th, 2008 AT 11:25 AM
