Is the MAP sensor a culprit, for the above problem as i replaced with orginal EGR valve and Solenoid and clean the exhaust manifold, still the ECL on. Is there a DPFE sensor/ EGR sensor availabe for this model. If so, where it is located in the car?. I feel lose of power in the car (not always), if i pump the accelerator periodically while on move the ECL is not active but if i go slow with less power on the accelerator pedal the ECL immediately lights up!!! please hep me with your valid answer................
Aug 1, 2009 at 7:07 PM
