2000 Toyota Camry Humming noise
165,000 MILES • 4 CYL • 2WD • AUTOMATIC
TSTOE
For the past several months I have been hearing a humming noise coming from the rear passanger side of the car. I had the wheel bearing assembly replaced, but that did not eliminate the noise. I have noticed that the noise will occur intermittantly while driving at speeds of 5 to 60 miles per hour. I generally do not hear anything when going faster than 60. Also, the noise only occurs when I am applying pressure to the gas pedel...if I remove my foot from the gas, the noise stops. Any suggestions on what it might be?
Jul 3, 2008 at 11:31 AM
KHLOW2008
  • 41,812 POSTS
Hi tstoe,
Can it be the fuel pump?
Check the exhaust system for misalignment resulting in it being too near or in contact with body.
Jul 4, 2008 at 3:31 AM
