For the past several months I have been hearing a humming noise coming from the rear passanger side of the car. I had the wheel bearing assembly replaced, but that did not eliminate the noise. I have noticed that the noise will occur intermittantly while driving at speeds of 5 to 60 miles per hour. I generally do not hear anything when going faster than 60. Also, the noise only occurs when I am applying pressure to the gas pedel...if I remove my foot from the gas, the noise stops. Any suggestions on what it might be?
Jul 3, 2008 at 11:31 AM
