2000 Toyota Camry Hard to get fuel into car
98,000 MILES • 4 CYL • 2WD • AUTOMATIC
ERICKSONMN
My 2000 Camry gives me a hard time when I put gas into the fuel tank. The fuel will go into the tank but with much effort. The handle on the fill spout will act like the tank is full when it is not'; I must fill a little at a time which takes a long time to fill the tank up with gasoline. What is the problem?
Oct 9, 2008 at 7:24 AM
  • 31,937 POSTS
Hi there,
you will need to get your mechanic to check the fuel tank venting system, you are getting an air lock causing your slow fill problems.
Mark (mhpautos)
Oct 9, 2008 at 9:20 AM
