2000 Toyota Camry Gauges and gear shift will not work
2000 TOYOTA CAMRY
75,000 MILES • 4 CYL • 2WD • AUTOMATIC
LIPENGR
I did drive the car for some time and attempted to trickle charge the battery. When I reconnected, several fuses blew. I replaced the battery and fuses. Now, the car will start but the entire dash is dead and I can not shift the car into gear.
Aug 15, 2008 at 2:31 AM
KHLOW2008
  • 41,814 POSTS
Hi Lipengr,
There must be at least one more fuse you have missed out. Check the brake fuse underhood.
Are the brake lights working?
Aug 17, 2008 at 12:10 AM
