2000 Toyota Camry Fuel System Problem
12,800 MILES • 4 CYL • 2WD • AUTOMATIC
RICHARD POKRYWKA
When attempting to fill the with gas the shutoff valve on the gas dispensor shuts off as if the tank is already full. I have to nurse the gas into the tank by repeatedly depressing and releasing the pump handle. I tried different orientations and gas pumps and even when dispensing slowly it still shuts off prematurely.
Dec 20, 2007 at 2:16 AM
  • 31,937 POSTS
Hi there,
You fuel tank venting system is not working, there is a vale system in the filler and a vent line that goes to the carbon canister, some part of this system has failed, it will be a job for a mechanic to inspect and rectify.
Mark (mhpautos)
Dec 20, 2007 at 8:36 PM
