The engine light is on in the dash. Hooked up a computer and the codes shows"poor flow at EGR Valve" checked to egr port it is clean. Check for proper vacume all is good. Is there anything thing else that I could check to figure this out
SPONSORED LINKS
Tuesday, January 8th, 2008 AT 12:33 AM
MECHANIC
Hi there,
The EGR valve may not be operating properly, clear codes and drive again. If same code set replace EGR or try to clean excessive carbon from port, try that first.
