2000 Toyota Camry code p1133 and p1135 and code po125
2000 TOYOTA CAMRY
120,000 MILES • 6 CYL • FWD • AUTOMATIC
MYQUESTION
how much it cost to replace air /fuel sensor?do i need to replace both in front and back? why they went bad ,is it because i use regular gasoline? how do i replace them? how much it cost to replace engine coolant temperatue sensor and how to replace it?
Jan 21, 2008 at 8:44 PM
LOSTINMARS
  • 222 POSTS
only 1 sensor is bad. its the one in the exhaust manifold near the firewall. replace it with a oem sensor from the dealer and it will fix all 3 codes. good luck getting it out. if it comes out okay it should run $350 give or take.
Jan 23, 2008 at 9:38 PM
SWEETWALLY
Exact Denso sensors can be purchased online and are usually in the $50 - $90 range. Only use Denso in Toyotas. They are sensitive to Ohm output from other brands.
Jan 29, 2013 at 11:23 PM
