2000 Toyota Camry Car acts like it floods out when its cold
REDNEKWIZARD
  • 30 POSTS
Engine Mechanical problem
2000 Toyota Camry 4 cyl Front Wheel Drive Automatic
I have a 2000 toyota camry, it has problems starting in the morning, it acts like it is flooding out, I had the codes ran and they came up as the ect sensor and the idle air control fault. I replaced the ect sensor and it still does it.
The idle air control is over two hundred dollars and I dont want to spend the money fixing it if thats not the problem.
Aug 26, 2010 at 2:54 AM
  • 75,988 POSTS
Why don't you just clean out the IACV and also the MAF sensor with an electronic cleaner CRC and also test the throttle position sensor
Aug 26, 2010 at 10:26 PM
