2000 Toyota Camry blower moter
2000 TOYOTA CAMRY
ALLTHE143
Heater problem
2000 Toyota Camry 4 cyl Front Wheel Drive Automatic
Wonder were the blower motor is located in a 2000 toyota camry. I think the bearing on the blower motor is no good in my girlfriends car. Every time the heat or ac is turned on it sounds like there is an outboard motor running behind her glove box. So i'm guessing i can take the glove box out and then replace the blower, i would like to no for sure before i start taking her car apart. Any suggestions would be helpful!
Thanks,
Mar 8, 2009 at 1:42 PM
Its behind the glove box-could be rubbing against the blower motor housing.
Mar 8, 2009 at 7:48 PM
